Fuel line nub came out of carb body
Started by Membername, July 14, 2019, 04:52:39 PM
Membername
I'm attaching the fuel lines (freeline) onto the carbs and the fuel connector came out of the carb body.  Do I just push it back in or do I need to glue it with something?
Thanks,
Karen
thatguy
I've had that happen a couple times on older carbs. I clean it well use a bit of Loctite 609 stud and bearing mount for insurance. Hasn't failed me yet.
Happens a lot...
Take it off the fuel line, lay it on it's side on the flat of your vice or steel work bench and use a small hammer a give it a slight wack to make it a bit out of round, clean with thinner, then use loctite and tap it back in place, let dry 24 hrs.
Good to go.
Quote from: Membername on July 14, 2019, 04:52:39 PM
Thanks,
Karen
Has happened one too many times with me.
