Gluing engine emblems
Started by D.e.e., August 31, 2019, 03:25:15 PM
D.e.e.
Anyone have a preferred glue for engine emblems?
Redbird
JB Weld makes a High Heat Epoxy that works really well. I've used it to reattach Corvette emblems to SBC valve covers with great results.
Quote from: Redbird on September 05, 2019, 07:26:02 AM
I was going to suggest an epoxy but they stuff will be so tough to remove if you need to get it off.
motodreams
1-min epoxy would be my choice.  No need to hold endlessly.  Strong but not end of world strong.  Double sided tape is likely best option unless you don't like the added mm of spacing.
i use a few dots of case sealant. or 3m spray on  done both.
Does anybody have r5 engine emblems they could recommend?
The circle Yamaha ones.
Doesn't hvc make some? I was going to design some and 3d print some.
