small end noise
Started by elliottles1, April 14, 2022, 10:41:36 AM
elliottles1
Dudes,
what does small end noise sound like please? i have a marble in a tin type rattle ONLY on tickover, nothing at any revs or on the over-run. the bore is fresh and measureably tight so i am wondering.
many thanks
les.
small end bearing noise will usually follow rpm. (sounds like an out of adjustment valve on a 4 stroke ) if its just on idle, prob piston skirt noise.
elliottles1
rito, investigations will continue then!
les.
