135-140 HP CASE REED H2
Built by Henry Wedge. 1st hand experience, it is indeed insane to ride.  :devil:
Dave F Mod
Started by Diablo007, October 18, 2020, 04:48:31 AM
Diablo007
Anyone have a pdf on the Dave F mod?  The link on Economy Cycle's site is dead and I can't seem to find them via a Google search.
2 stroke junkie:
i just pdf'd this. I have had this forever. keep in mind, its dated. but the carb mods are still accurate. http://www.2strokeworld.net/forum/index.php?topic=2566.0
:cheerleader:
Economy Cycle John
Quote from: Diablo007 on October 18, 2020, 04:48:31 AM
I fixed that link and here's some additional instructions / Pictures
https://files.secureserver.net/0sxTWBlyTWlOB6
John
Diablo007
2 stroke junkie:
NYSingh
I recorded when I had to do the mod on a new carb recently and finally just uploaded it.  I didn't show the removing/re-installing of the mains/pilots/needle jet/jet needle since those are simple enough to figure out using the PDF.  The first time I did it I struggled most with the brass ball (and I still did, as shown in the video!), so I focused on that portion. Please chime in if I've mis-stated anything in the video so I can post a corrected version.
Also re-attaching the PDF
Moto Guzzi V7III
 :clap: for those visual learners
There was something about cutting down the little piece that sticks into the carb by 2mm that I dont see in the pdf. I think it was something that Chuck mentioned
NYSingh
Per Dr Q:
QuoteI use 169-P2's and cut the spray shroud 1.7mm.
210's on the mains will about right.
I always start with 35 pilots on Spec II PIPES.
I'm usually also using my TSR/Barlow boost bottle/Banshee manifolds and yz125 reed petals on the stock cages.
So your on the right track. Don't cut the P0's if you use them.
5DP7--2 or 3 is good on a 2.0 airjet.
This was for a ported RD350 w JL pipes.  Someone else in the thread mentioned 2.0mm for the RD400.
http://www.2strokeworld.net/forum/index.php?topic=136.msg705#msg705
Moto Guzzi V7III
