Rd400 fork assembly wtf
Started by rd400greenhorn, February 18, 2021, 01:59:23 PM
rd400greenhorn
Yeah so, thought it was a quick and easy job..
Apparently iam an idiot 😅
I Cant get the buttom bolt to catch the thread Inside the fork tube
I beleieve i have even tried every combi..
Makes No sense, done it for hours 😅
Its the right bolt as this was Taking apart of a functioning fork 8 months ago..
Anyone 🤔
take spring and cap off, insert broom handle.turn fork upside down, press down on assembly . start thread by hand with hex key. if hole isnt lining up, use a cross-head screwdriver, carefully, to align through hole. if that wont work, check make sure threads on bolt or rod arent damaged.
rd400greenhorn
This is basically what i have been doing, just Cant hack it it seems haha.
So wierd i really dont get it
bitzz
Thread a stud into the inner fork tube thingme. Or cut the head off a long bolt and use that
Drop the inner thingme into the fork lower so the stud sticks out of the hole.
Jam broom handle in to hold it in place and flip it upside down
Remove the stud and screw in the bolt.
Don't forget the copper washer and anneal it before you use it.
rd400greenhorn
Yeah so
Does this look right, buttom of the fork
Yes, but no....
That's the bottom of the stanchion but where's the damper rod and the tapered bottom part?  Take out the damper rod and if it has the bottom part still fitted, slip it off and slide the damper rod back all the way through the fork leg and then refit the bottom hydraulic stop ( the 1" tall aluminum part.
rd400greenhorn
So what about that tapered alu piece at the end of the damper rod?
Do I fit that after from the buttom or? 🤔🤔
rd400greenhorn
Ahh this must be right.
Done it like this and up the buttom of the fork tube
Cought the thread right away...
Jesus.. Please say Its right 😂
rd400greenhorn
Is this right?
Kind of easy to pull the inner tube upwards and out because the snap ring gives..
rd400greenhorn
I got it 😁
Not like i suggestid, Its done right now. 👌👌
rd400greenhorn
Corrected.
It came together nicely until the spring came in and Cap
Snap ring in the buttom gave away and it could be puller apart..
Anyone?  :umm:
rd400greenhorn
This is how it is put together in the buttom. Held in place by snapring, minus the aluminium piece Which sits in the buttom of the lower leg
... i have no idea what you did to those forks but that certainly doesnt look right.
Quote from: m in sc on February 19, 2021, 02:10:50 PM
Glad its not just me, I'm very confused.
