Oil spigot?
Started by soonerbillz, April 15, 2021, 06:43:56 PM
Are the oil supply spigot on the R5 cylinders screwed in or pushed?
Can they be removed?
They are screwed in with Banjo Bolts... use a Phillips or small wrench on them to back them out.  When replacing, use fresh copper crush washers.
The banjos are these. https://hvccycle.net/yamaha-oil-injection-banjo-bolt-90401-06001-00-137-13165-00-00/ and the crush washers are these https://hvccycle.net/oil-injection-bolt-washer/
So they are just like my early enduros.. ok. Thanks
depends on the year of the cyl. early ones can be pressed in.  will be real obvious looking at it.
Economy Cycle John
Quote from: Economy Cycle on April 16, 2021, 01:45:11 PM
FWIW we stock all the R5 injection parts and use forum code 2SW for a discount.
https://www.economycycle.com/product-category/yamaha-rd250350400r5ds6ds7-parts/engine-related/oil-pump/\
Thanks.. and just a heads up.. I will be making a big order list for you fill sir.
In the next few weeks. I need lots of your R5 parts.  :wave:
Quote from: m in sc on April 16, 2021, 08:15:20 AM
Thanks.. will look at them closely.
