Replacement ignition switch
Started by Galensmitty, April 02, 2019, 10:21:03 AM
Galensmitty
Good morning!
My ignition switch for my 74 rd350 is worn out and broken. Are there any recommendations for replacement ones? I see that HVC sells ones for the R5. Do they not fit the 73, 74 and 75 rd's?
I believe the DS7/R5 switch is different -- screw locations and wire connectors
Why not get an OEM one off Ebay? There are used ones or even NOS available. A part for a 73-75 RD250 or RD350, or 73-74 TX500, or 75 XS500B will fit.
360-82508-09-00 (or 360-82508-43-00)
Jessup
Leonelli magnetic lanyard switches are reliable. They're simple, maintenance-free, and cheaper than mechanical key switches.
It's on the internet, it must be true :whistle:
Pretty cool.
Could you just just wire a cheap ignition switch from flea bay?
Redbird
#5
I used a repro RZ/RD350 ignition switch on my DS7. It bolted right up, but as SoCal mentioned, the connector is different. I simply repinned the wires into the old connector.
Like this one...
https://hvccycle.net/yamaha-1978-1988-reproduction-ignition-switch-with-keys-and-fork-lock/
If you're looking for just functional, that should work for you with little modification.
