Have you ever seen this before?
Started by Milan, June 13, 2022, 06:17:13 PM
Milan
These pipes came off the 350 I am working on.
The one in another post that is only running in 1 cylinder.
Do you think, while the PO was riding, if the 1 cylinder stopped firing, would this have caused this blowout?
Ws76133
I'd think it could if the spark returned after the silencer and chamber filled with unburned fuel.  When I was in high school, admittedly years ago, I'd switch the ignition off on my car while rolling down the road; turning it back on gave a loud backfire.  One of those opened the muffler along the weld seam.
msr
To this day, my 50+ year old brother will do this on any carbureted bike he owns.
Quote from: msr on June 14, 2022, 09:50:33 AM
:lol:
Wonder if he filled his pants when it blew.
I cant see that blowing up being the cause of that. It would have ballooned out a bit at least. There is also other damage on the tube a bit closer to the stinger.
Ive had really bad backfires pop the pipe off at the cylinder flange as that's probably the easiest spot to release pressure.
agreed. that wasnt a backfire issue IMHO either, but i bet theres a good story there. My guess would be a crack in the aluminum that wasn't caught in time and eventually got completely out of hand.
What he said.
That's not an explosion type failure.  If you look at the ragged edge you will probably see dirty parts where it was cracked for a long time and siny parts where the two parts fretted against each other. It does look like a fatigue crack.
