TZR250 3XV2 waiting for some attention
Started by busa1300, February 26, 2023, 05:46:42 PM
busa1300
I bought this bike over 3 years ago, and brought it in from Japan.
It was advertised as a non runner and had no information on why it wasn't running.
But it was very complete and a rare homologation 1 of 500 bike, so I bought it.
When I got it home, I unboxed it and first thing I did was a compression test to see if it was worth the time trying to get it running.
Had excellent compression so I pulled the carbs and cleaned them up, put them back on and got the bike fired up.
No noises and seemed to run quite well considering it was a non runner.... (choke was broke off which I think is why it ended up sitting)
But after I got it running, I noticed my trans oil had water getting in it, so I pulled the trans to get at the seal, and put all new seals throughout the tans and some bearings as well.
Started riding it and ran for that year with no issues.....
But now 3 years later, it is not being as cooperative
It needs a complete rebuild, and luckily I bought most of the parts I needed before covid wiped out the stock of now NLA parts
But I am hoping I can getting running like it had been and put it off for another year, as I was planning on going through my RS250 instead.
Well....time to dig in
RZ350-RZV500R-TZR250RSP 3XV2
TS/TM400 supermoto style...
busa1300
I ended up finding that the engine/trans need a full 100% rebuild. It is not going anywhere under its own power anytime soon. I have most of the extremely difficult to find parts already...most of them....
But no patience for such a detailed project that this needs to be.
So it's off the table as I look for a few last bits, and I have another much simpler project on the table now.
It's a beautiful bike and reminds me of a V twin TZ but I don't suppose any parts would cross over even if they were available.
Quote from: teazer on June 04, 2023, 04:16:42 PMIt's a beautiful bike and reminds me of a V twin TZ but I don't suppose any parts would cross over even if they were available.
Actually, a surprising amount of 4DP TZ parts crossover to this model of TZR.
busa1300
#4
Actually the basic bike is a street version of the 3YL. The crankcases are identical except for the holes drilled for the generator. The SP crank is identical to the TZ except the ends on the 3XV2 are keyed and the 4DP is splined. SP forks are identical to the 3YL 4DP. TZ cylinders will bolt directly on the cases as will basically everything else from a TZ motor.
Have been searching and trying to collect bits for it still. The Yen is way down at the moment so I managed to buy a TZ 4DP 3.75x17 front wheel and a set of 4DP Brembo rotors this week (to go along with the 83mm TZ250 calipers I already have) Still no luck on a 4DP rear wheel....
The 91 3YL.... First v-twin TZ
