:toot:  Happy 2026! :toot:
Transmission linkage tuning
Started by pdxjim, April 09, 2023, 12:51:08 AM
I got out for a ride today, and was reminded of a nagging issue in the trans linkage and mechanism behind the right side cover.
Upshifts are flawless, and downshifting 6-5, 5-4 are effortless, but 4-3, 3-2, and especially 2-1 require a little more left leg action than usual.
It feels like the pedal goes down without engaging or something?  I suspect its the adjustment at the star wheel, stopper lever or shift shaft assembly behind the right sidecover.
Anyone got any tips for me?  I wanna get this thing dailed in 100% asap.
I don't ever remember adjusting one but this needs to be centered properly.
shifter" border="0
The Ausgleichworrichtung is fercockt. ...And don't forget to tighten the Sicherungsmutter.
make sure the bushing on the arm is there or it'll slop around in the slot. ive seen that missed a few times
FWIW, the stock LC gear lever and linkage is not really a good design. The "arm" for the linkage on the pedal is VERY short, and I assume the arm on the shaft is fairly short as well. This leverage ratio will exaggerate any slop in the heim joints, and cause higher loads/ more friction at the pivot and the shaft. So it should not really be a surprise that shifting is less than perfect after 40 plus years. Still, the already mentioned adjustment may well be required.
Ive changed the linkage setups on my bikes to a straight shift leaver and GP shift pattern. It gives a better shift feel and better shifts into second gear.
Check out factorypro.com, I think they may have what you are looking for to solve your problem.
I found the issue.  The torsion spring that centers the shift claw is worn and doesn't keep the claw centered as it should.
Found a new shift shaft assembly at Parzilla, so barring some other hiccup, it looks like we're in business.
