Front brake system service - Yamaha RD400F
Started by SoCal250, May 14, 2025, 08:22:41 PM
I'm in the process of servicing the front brake on my Daytona which was in need of a full teardown as the caliper was dragging badly. So, today's project was "get the stuck piston removed". After removing everything from the bike and breaking everything down, I couldn't get the piston out of the caliper with air. I went up to 75psi and it wasn't budging after it got to a little more than halfway.
I decided to use Ken's (kpke) trick of wedging sockets into the ID of the piston and twisting it out with a ratchet and socket extension, but even that didn't work.
So I went to the method that I used on my TZR last year which takes Ken's trick one step further. I heated up the caliper in the BBQ at 225F for about 20-30 minutes and then melted a couple ice cubes in the ID of the piston. After draining the water out, I then went to Ken's trick and the piston came right out with some easy twisting. :thumbs:  :cheerleader:
After several round in the ultrasonic, detailed clean up, and masking, I'm off to the next step tomorrow - paint and then bake in the BBQ.
Nice Russ, I just stored that trick into my data base.
Looking good. I just did the grease gun method on my RZ calipers. Oh what a mess that makes.
