Transmission bearings for 73' RD350
Started by 2t Fan, October 10, 2025, 02:51:31 AM
2t Fan
Can anyone help me with the generic transmission bearing no.s for the air-cooled '73 RD350
Thanks
The bearing numbers are listed in the specs in the back of the service manual.
2t Fan
2t Fan
Quote from: 1976RD400C on October 10, 2025, 08:01:43 AMThe bearing numbers are listed in the specs in the back of the service manual.
ok thanks. Let me check it out
Wow #14 is an expensive one! When ordering make sure you get replacements with the correct features as some of these have circlip grooves in the OD, etc. The Partzilla diagram mentioned above has photos of the parts you can use for reference
#     PART NUMBER      DESCRIPTION
12   93311-22027-00   BEARING, CYLINDRICAL 20-30-15
14   93305-20502-00 (93305-20508-00)   BEARING B5205 Special 25-52-20.6
24   93310-22057-00   BEARING K20-24-10 S
27   93311-42045-00   BEARING, CYLINDRICAL 20NQ3315NE 20-33-15
31   93306-30504-00   BEARING B6305N
2t Fan
#6
Quote from: SoCal250 on October 10, 2025, 12:51:41 PMWow #14 is an expensive one! When ordering make sure you get replacements with the correct features as some of these have circlip grooves in the OD, etc. The Partzilla diagram mentioned above has photos of the parts you can use for reference
thanks SoCal250
Managed to find below , not sure if they are exact replacements
B6305N
20-33-15 -20NQ3315NE (Koyo)
20-24-10 -K20-24X10 S (Koyo)
B5205 Special
20-30-15 - RV203015-JTEKT (Koyo)
klaird
I replaced all of transmission bearings on 75 RD  last winter. Ordered from "Yamaha Parts Online" (babbitts) and the prices were very  reasonable $218 bucks for all of them, all OE.
It's a little more expensive these days
                             MSRP  Babbitts   Partzilla
93311-22027-00    $52.99  $41.33   $37.39
93305-20502-00    $125.99 $98.27   $92.92
93310-22057-00    $42.99  $33.53   $33.41
93311-42045-00    $32.15  $25.08   $26.31
93306-30504-00    $71.99  $56.15   $56.13
                TOTAL    $326.11  $254.36  $246.16
Here's what Yambits sent for a RD400 countershaft ($20) and clutch shaft ($33) bearings.
2 Smoker
Quote from: SoCal250 on October 11, 2025, 12:38:29 PMIt's a little more expensive these days
Nice research Russ
