broken kickstand mount
Started by gargantua350, January 25, 2026, 09:00:35 PM
Dvsrd and 1 Guest are viewing this topic.
gargantua350
Hello
I have a broken kickstand mount that has been re-welded several times.  The finally tab broke off completely and I would like to re-weld forward on the bottom frame tube since I have spec 2 chambers.  Have you guys used aftermarket kickstand tabs or used the stock one and just relocated?
thanks for the help
ive seen a zx7 kickstand welded on the sidetube. me, ive always used a sticker and relocated it
I also had a broken kickstand bracket on my RD350. I ended up making a reinforcement bracket, that tied to both the bottom AND top plate of the frame crossmember. It is now rock solid 😀
