RD400 racing brake pads
Started by triple1972, February 04, 2020, 12:49:44 AM
triple1972
Hi! Quick question for racers or ex racers. What type and brand do you recommend. Lots of choices out there but what are guys using? Thank You!!!
Quote from: triple1972 on February 04, 2020, 12:49:44 AM
I believe pad material depends a lot on disc material, i.e cast iron vs stainless vs other special steels. EBC HH are often recommended by some disc manufacturers.
Quote from: Dvsrd on February 04, 2020, 07:30:54 AM
Correct, and Vintage Brake will suggest and sell you the pads that suit your set up the best.
Plasticman
There's some great information on that webpage (vintagebrake.com).
Rob
1976 - RD400 - road racer
SBS's are great on stock disks, better than the EBC's
triple1972
Thanks Chuck. Part number or maybe just material recommendation. Not sure how many different they offer. Economy sells sbs and says good for street or race.
SBS Part # is 504HF (stock 2 piston caliper)
They say street on the package, but work great even for track on the stock disks.
Race pads are too aggressive for the stock rotors and over heat them so they warp bad or fade late in the race because of excessive heat.
triple1972
Found the SBS pads! Readily available thanks! About 30$.
Quote from: triple1972 on February 13, 2020, 12:36:05 AM
Economy sells the 504HF (1721-1533). And you get a 10% discount.  ;)
triple1972
Yes Russ, I am going to get the Galfer braided lines also! Do I need an adapter to attach these brake lines to Oem or repop calipers?
I believe the front Galfer hose comes with the necessary adapter for the caliper . The rear should be a direct swap.
