Clutch actuation rd400
Started by rd400greenhorn, April 12, 2020, 07:49:40 AM
JB Weld
So if my pressure plate is seated all the way to the clutches and still won't actuate, what could the deal be?
Not trying to be redundant, but my clutch doesn't work after rebuild and it did before.
I tried adjusting but it didn't work and I'm 99% certain I installed the ball on the clutch side. I might just try what the OP did and remove some screws and see it it moves.
Did you have the worn gear and or the base of the worm gear out of side cover?
C
JB Weld
Yes. Removed them to blast the paint off. Also removed the "worm" the other day to free up the lock but because I thought I was going to damage the plastic in the base.
Quote from: JB Weld on April 20, 2020, 08:13:45 PM
So there is a 1% chance you didn't re-install the ball? Also, make sure there is a ball captured in the actuator as they do fall out sometimes.
rd400greenhorn
I got it to work guys
The Ball was missing on the clutch side
So far so good
JB Weld
So I know I hi-jacked this post. Just an update. I have mine figured out. I think the pressure plate and clutches may have been sticking together because it sat too long without oil in the trans. A couple light taps with a deadblow and it works. Thanks for the assist Joe!  :righteous:
Quote from: JB Weld on April 21, 2020, 08:34:32 PM
No problem.
