HPI ignition install
Started by turtle, March 24, 2019, 10:21:06 AM
Quote from: pdxjim on April 09, 2019, 12:24:41 PM
You can order direct from HPI for around $250 + shipping from Belgium.
Yeah, but you get to support such a great small company. They will literally bend over backwards to help people out.
turtle
I still not have installed it yet. I a bit lost on timing as there is marks all over the place and the directions are terrible. also looking for a place to mount the coil and the little rectifier.
idr5c
Make sure you confirm the timing via a timing light on the HPI once installed. Mine doesn't fire when the rotor & stator marks are lined up, it triggers a little before. In other words, if you line up the marks and set the timing at 2.0mm BTDC, it will actually fire at 2.3mm (on mine).
Stephen Phillips
WMRRA #494
http://www.wmrra.com
true, i had to adjust it with the plate, was easy, but definitely verify :twocents:
turtle
IF I'm shooting for 1.8mm BTDC timing how is a timing  light going to verify this? I thought the timing was set with a dial indicator. I really wish they had a step by step install manual.
idr5c
Quote from: turtle on May 07, 2019, 11:31:14 AM
Ignition timing is set with a dial indicator, but you can verify that it is correct with a timing light.
Look at the top picture in the PDF below:
http://www.kreidler.be/general%20downloads/HPI%20210_1C2T_eng.pdf
For counter-clockwise rotation, the ignition should fire when the rotor mark is aligned with the left mark on the stator. Use a dial indicator to place the piston/crank at 1.8mm BTDC (or whatever timing you choose), then rotate the stator to align the left mark with the rotor mark.
To verify the timing, clip your timing light onto a spark plug lead and start the engine. At 3.5-4k rpm the rotor mark and the left stator mark should be lined up. If none of this makes any sense, find a forum member that lives nearby to help you.
Stephen Phillips
WMRRA #494
Krister
Don´t forget that HPI both advance and retard timing.
From zero rpm to 3500 it advances timing 10° (from 15 to 25°) and holds to 4500, after that retards another 12,5° at 10000 rpm, don´t have these values in mm.
I have saved some info from old site but don´t know who to credit for this :umm:
Setting at 3,2m gives:
2000>2,9 mm btdc
3000>3,1
4000>3,4
5000>3,1
6000>2,4
7000>2,0
8000>1,7
9000>1,3
10000>0,9
Can someone (who knows what they're talking about) recommended proper timing setting for HPI on "stage 1" tuned RD350 on premium pump gas?
i set the base marks at 1.9 on mine, try 1.8 to 1.9
turtle
i see you used a nut to hold the rotor to the crankshaft but on my 75 it's a bolt. going to need to find a small bolt as well.
that's because I used an LC crank, long story. yes, you'll use an m7 bolt
dugsgms
So whats involved in integrating the HPI lighting coil into the OEM 12v system? Is it merely connecting the new RR output to the existing red wire?
1970 BSA Lightning
1975 Yamaha RD350
1975 Honda CB400f
2008 Yamaha WR250R
turtle
NEW ISSUE.... I purchased an m7x20 bolt for the crank to mount the rotor and it still slips( the rotor) with the bolt tight. there is basically no interference fit between the crank and the rotor.  i'm going to send them an email to see what they say.
interesting, 1st i heard of that. are you sure you ordered it for an early small taper rd? the later ones (european) were larger tapers i think. the lc and rz certainly was. they may have sent the wrong rotor on their own mistake.
regarding the 12v thing, yea, should be it.
