My Birthday/Christmas present from the Bridal Unit
Started by Kawtriplefreak, December 12, 2022, 09:04:30 PM
I have been busy so unpacking it and finding a place for it to live in the shop is as far as I have gotten. It is a Vevor 30 liter. I am planning on trying it out soon with the crusty calipers on the Gray Ghost RZ...
Nice! :clap: Happy Birthday and Merry Christmas!
Congrats! Same one I have. When I unboxed it I first thought it was too large, but after a few years of using it I've learned that my first assumption was way off.
The Red Scourge
Looks like a nice big one!  I bought the biggest one I could get.  I haven't used it a lot yet, but it works well when I need it.
'76 Yamaha RD400C
'71 Kawasaki G3SS
'88 Honda CBR400RR
'90 Yamaha FZR400/600 hybrid
You'll love that Tim! Good that you got a large capacity one. I'm on my 3rd one in 8 years having stepped up capacity each time. Have a 15L now. They have been well used in my defense (no fault of the ultrasonic) as have cleaned over 180 master cylinders, 75 brake calipers, and around 30 carbs. I generally do two heated 30 minute cycle cleanings for each basket. You'll wonder how you functioned before without one!
im curious on this as well, I know what i use and have for almost 30 yrs..... lets see what everyone else uses.
:toot:
busa1300
Don't use Simple Green with heat for too long or your carbs will turn black.
RZ350-RZV500R-TZR250RSP 3XV2
TS/TM400 supermoto style...
The Red Scourge
I use Simple Green Pro HD, it's safe for aluminum.  I've had decent success in limited use.
'76 Yamaha RD400C
'71 Kawasaki G3SS
'88 Honda CBR400RR
Simple Green HD is great on carbs. I have done hundreds in it, and it is pretty sweet. I don't mix it to full strength, instead i go about 20% under.
I pre dip all items in water and dish soap. And ultrasonic tank is a game changer for certain things. A great tool for cleaning and prepping parts.
BlueR32
Quote from: sav0r on December 14, 2022, 12:01:27 PM
So what is the optimal mix ratio of Simple Green to water for ultrasonic cleaning?
I use Extreme Simple Green Aircraft and Precision Cleaner
I think the last batch was 1:4  And I normally run one or two 20-25 min cycles with temp of 50-55C
Daytona1
About to clean some cb carbs and was planning to use a 50/50 mix of carb cleaner dip and wd-40 in the ultra sonic tank. Seems like chuck q might have recommended it. But curious to see what others think.
^ thats what i use. Only downside is its smelly, but i drain my tank after every use.
Mark,
Carb cleaner as in Berrymans the stinky one that comes in a gallon can with a basket?
Daytona1
Now that I think about it. It might have been Marc who recommended this blend. Curious if this is only for carbs if so what do you use for other stuff and do you use a rinse of anything?
