Whats in my garage
Started by busa1300, March 24, 2019, 06:11:25 PM
busa1300
#150
Slow progress on the TS/TM400
Collecting bits for it has been a challenge to some degree, but eventually finding what I want.
New pipe, ignition, carb, bearings throughout, piston, TM400 trans and so on....
RZ350-RZV500R-TZR250RSP 3XV2
TS/TM400 supermoto style...
busa1300
Spokes tightened and trued up.
Tires mounted and balanced, confirming that I will have chain clearance and I believe clearance for my front brake torque arm.
busa1300
Just about to the point of stripping the bike 100% apart now that I know how I want it to look....
Very nice!
Randy, don't know if you saw this, but I posted it with you in mind.
https://www.2strokeworld.net/forum/index.php?topic=6058.0
busa1300
Thanks guys  :thumbs:
I did not see the post until now, but I did respond :olaf:
busa1300
Frame is ready for its next life...used polyuroxy black for primer, and then clear coated with about 10% flatner to give it the right look.
....just need to get some motivation, and my chemicals for my replating of nuts/bolts/axles...
That is going to be a "jaw dropping" WTF is that!
2004 Honda Helix
busa1300
Quote from: dgorms on January 25, 2024, 09:16:59 PMThat is going to be a "jaw dropping" WTF is that!
It's the frame from the above TM/TS400 project.
Have a set of fork tubes ordered from franks forks, as the originals had been slightly bent. A set of aluminum body Icons for the rear have been waiting in a box to get used.
Using a set of aluminum TM triples to replace the bent (steering stop) heavy steel original TS version
Randy, I love that Jemco and I predict that bike will be giggle-in-the-helmet fun for you. Great project and your write-ups are always entertaining  :thumbs:
busa1300
Quote from: 85RZwade on January 26, 2024, 11:56:35 AMRandy, I love that Jemco and I predict that bike will be giggle-in-the-helmet fun for you. Great project and your write-ups are always entertaining  :thumbs:
Thanks  :thumbs:
Wish I could write up more, but the older I get the more I think about doing, and the less I actually do... :umm:
busa1300
Bit by bit....
Doing my own replating again.
I second that. Very cool indeed.
