Whats in my garage
Started by busa1300, March 24, 2019, 06:11:25 PM
busa1300
Thanks guys  :thumbs:
Still have a long way to go.
Fork's showed up today, (after 9 weeks) so I did a dry build on them with some rebound spacers to drop it a little. Still want the front a little lower, but with some weight on it, it should level out when completely done.
Will hopefully get some emulators ordered next week sometime, then I can put the front end on for good.
RZ350-RZV500R-TZR250RSP 3XV2
TS/TM400 supermoto style...
busa1300
:cheers:
I got my tapered head bearings installed. Emulators came this week also, and then made some measurements from them and my lowering spacer. Cut my springs today to get the right preload, and did another dry build of them to see if my calculations got the bike to level out like I wanted.
Looks like what I had in mind, so apart the fork go again and then add the piston ring, oil seals, dust caps, and oil...then I'll be done with the front for good....I hope
Time to turn some attention...and $$$ to the motor rebuild now.
Wow, that's looking fantastic! :clap:
busa1300
 :cheers:
Thanks guys.
It is going on one year since I brought this bike home....and still no where close to being done. Think my days of rebuilding are starting to come to a close.
busa1300
A quick vid of slow progress
Will finally get the crank and cylinder sent out within the next week so I can start on the engine soon.
busa1300
TM400 Cylinder and crank have shown up, after being worked over by Bill Bune Industries.
Time to get all my bits back together and make sure nothing has been misplaced in the past year....
That looks wicked.  How wide are the rims?
busa1300
Quote from: teazer on August 28, 2024, 04:35:31 PMThat looks wicked.  How wide are the rims?
 :thumbs:
Rims are 17x4.25 and 17x3...
110x70 and 150x60 Dunlop Alpha 13's
You going to the AMSNOW event at Martin this year?
oh man thats going to be a weapon.  :olaf:  :nana:  :metal:  :cheerleader:
Rgvnfla
Hey Busa, thanks for the advice on my 400 top end . I changed up on the color and I got it all back together and presentable at this stage,I need to spend some time on my RGV. Your bike will be amazing! I may have some engine parts if you need seals and such.what ignition are you going to run?
