RD250 with 350 top end jetting
Started by RD350NL, February 03, 2025, 06:56:09 AM
RD350NL
Hi all
I am in the process of converting my rd250b to a 350. For the jetting I referred to the manual, which indicates I should use 25 pilot and 130 main. Currently I am running 27.5 pilot and 120 main, the 250 top end runs great with this jetting. The concern I am having is that virtually everywhere I read the main should be 140 when running 350.
Can someone confirm the manual has a typo? Or should 25 pilot and 130 be fine.
PS: Bike is bone stock (does have a Vape ignition)
Thanks already
Just go rich and see. It can't hurt.
that jetting also applies to a stock airbox, stock 350 carbs. us market rd350s were indeed 140 73& 74. so, the jet tubes have to be the same as a 350 and all sirbox parts in place w a stock filter, etc. otherwise,  the jetting will need to be figured out. 250/350 airboxes etc are the same as are the carbs,  but I'm pretty sure the jet tube and needle for both are 0-8 and 514 in the middle clip
stresa
@RD350NL
I have a couple of carb charts, parts lists and manuals, both USA and Europe versions, but not in one is a #130 stated for a 350. For a 73/74 350 always the numbers Mark stated or a #105 main jet, 5L3 needle, 2.0 carb slide with a baffled airfilter for the 1975 Europe B model which was a slightly different model to the USA B ones.
But carb fine tuning always depends on your own engine.
As @sav0r wrote. Start rich and work down if needed.
Regards Uwe
81 Jackson 250,2x 74 RD250 racer,78 RD400 2R9,77 RD400 1A1,72 R5/RD350 rat,74 RD250 streettracker,75 Yapol TZ250,3x 76 TZ2/350,89 Honda RS125,
80 Hejira PE250,77 Höpfner-TD3,76 RD/TD3,75 TZ/RD250A,78 Siroko TZ250,86 Tomic 200,91 TDR250,86 TZR250,2x 94 FZ750,86 FZ750/1000,99 TDM850
