RD250 with 350 top end jetting
Started by RD350NL, February 03, 2025, 06:56:09 AM
RD350NL
Hi all
I am in the process of converting my rd250b to a 350. For the jetting I referred to the manual, which indicates I should use 25 pilot and 130 main. Currently I am running 27.5 pilot and 120 main, the 250 top end runs great with this jetting. The concern I am having is that virtually everywhere I read the main should be 140 when running 350.
Can someone confirm the manual has a typo? Or should 25 pilot and 130 be fine.
PS: Bike is bone stock (does have a Vape ignition)
Thanks already
Just go rich and see. It can't hurt.
that jetting also applies to a stock airbox, stock 350 carbs. us market rd350s were indeed 140 73& 74. so, the jet tubes have to be the same as a 350 and all sirbox parts in place w a stock filter, etc. otherwise,  the jetting will need to be figured out. 250/350 airboxes etc are the same as are the carbs,  but I'm pretty sure the jet tube and needle for both are 0-8 and 514 in the middle clip
stresa
@RD350NL
I have a couple of carb charts, parts lists and manuals, both USA and Europe versions, but not in one is a #130 stated for a 350. For a 73/74 350 always the numbers Mark stated or a #105 main jet, 5L3 needle, 2.0 carb slide with a baffled airfilter for the 1975 Europe B model which was a slightly different model to the USA B ones.
But carb fine tuning always depends on your own engine.
As @sav0r wrote. Start rich and work down if needed.
Regards Uwe
81 Jackson Special 250, 2x 74 Yamaha RD250 352 racer, 78 Yamaha RD400 2R9, 77 Yamaha RD400 1A1, 72 R5/RD350 rat, 74 RD250 streettracker, 72 DS7, 75 Yapol TZ250, 89 Honda RS125,
80 Hejira TM250, 77 Höpfner-TD3, 76 RD/TD3,
75 Yamaha TZ/RD250A, 78 Siroko TZ250, 80 TZ350G, Tomic 200
