Brake adapter for blue or gold dot caliper and big rotor on RD
Started by m in sc, March 01, 2019, 12:19:07 AM
this is an adapter for a blue or gold dot caliper to be used on aircooled rd250/350/400 front forks. use at own risk. Mine is made of 6061 aluminum. you will need to run an fzr600 or like rotor, and make a **EDIT**13mm OR 1/2" spacer behind the rotor. (center of a stock rd rotor hat also works)
this is a link to the zip file which contains a .dxf of the main adapter.  https://2strokeworld.net/wp-content/uploads/2019/03/brakeadapter-r6-rd-v4.zip
i would recommend a MINIMUM thickness of 3/8" no bigger than 1/2" feel free to take the linework and modify to suit your cosmetic needs.
I JUST have the adapter in DXF format available. Any decent machine shop can get this cut, or water jet or laser shop.
This is MY file, do NOT copy and make as batch and sell for a profit, please.  This is strictly for personal use for projects.  If you do, and i find out, i will expose you and any personal data i have on you for the dirtbag you are.  You have been warned.
You will have to fit and finish the part yourself.
For RZ350 owners, TDR (Tony Doukas Racing) sells the adapter for the nice beefy R1 components to bolt up to stock RZ fork lowers. A great upgrade and one finger braking but you have to exercise caution with this level of stopping ability.
Kudos to Mark for sharing the file to RD owners!  :clap:
2004 Honda Helix
Plus one Evans on the TDR adapters. I have them on my RZ and the difference in braking is amazing!
JB Weld
Looks great. Any good reason to mount this rearward on opposite side of original?
I apologize for ignorance as I didn't really grow up around two strokes or race bikes. Dad had a SOHC XS400 and uncles had Harley's and Viragos...
Rear mounting puts the mounting in compression, which should make it stiffer, but also allow the mounting to be lighter. Also, marginally less polar moment of inertia, that's unlikely to make any real difference but it's fun to do anyways.
350GUY
just fyi, with dims. Had a slow afternoon so ^
and you can download the pdf or jpg of this here (will be clearer)
pdf:
https://2strokeworld.net/wp-content/uploads/general-tech/brake-caliper-adapter-rd.pdf
jpg:
https://2strokeworld.net/wp-content/uploads/general-tech/brake-caliper-adapter-rd.jpg
irk_miller
Why are you guys running a heavy, semi-floating 4 pot caliper on an RD? A stock RD is 100 to 150lbs lighter with 25% of the torque and horsepower as an R1. A 2 pot floating Nissin from an SV650 with the same rotors is borderline too much brake and they're easier to adapt. Even if you're running chambers and tuned to 50-60 hp, I don't see it. It may even be less safe.
lighter by miles than a stock caliper, and basically the same as my TZR250 (which is 308lbs stock). (direct swap actually). I had 2 on my lc, it was a bit overkill but one is perfect. dont knock it till you try it.
This Old Daytona
Quote from: irk_miller on November 18, 2023, 09:35:47 PMWhy are you guys running a heavy, semi-floating 4 pot caliper on an RD? A stock RD is 100 to 150lbs lighter with 25% of the torque and horsepower as an R1. A 2 pot floating Nissin from an SV650 with the same rotors is borderline too much brake and they're easier to adapt. Even if you're running chambers and tuned to 50-60 hp, I don't see it. It may even be less safe.
Elaborate on your SV setup, with detail if possible.
I think I have a FZR setup, but don't know. Gonna need help identifying components.
But open to swapping out for other low buck  options
Thanks
irk_miller
Quote from: This Old Daytona on December 06, 2023, 02:34:03 AM
Thanks
I may have mispoke and said Nissin, but they are actually Tokico.  This is a pic with Honda forks that I originally ran on my RD.  The hub is also from a 500cc and above 70s Honda, which is the same rotor pattern as XS650.  Initially, I had it set up with dual disc, but that was way too much brake and unnecessary weight (trying to keep the bike under 270 lbs), so I removed the right side brake.
Here it is with the right side brake still on.  If you closely in the pic, it's a really simple piece of flat stock (and spacers) to make the mount for that front end.
I now have a TL1000r front end on the RD, so here is the mount for that setup:
Jung
Many thanks for this M in SC. Cool part! I was planning on making one but as I'm a bit short on time, I just sent off the dxf to Sendcutsend. Technology is a wonder! Cheers.
Vintagewannabe
I recently set all of this up on My 73 Rad350, and wanted to share some pieces. I used the FZR rotor, and designed the spacer on sendcutsend. The spacer was 105mm OD, could have been a cluple mil smaller to match up with the hub, but still looks very good, and was abit too snug with 64mm ID. 65 would have probably been better. The bolt holes were 8.5mm, 80.5mm across, center to center.
The 8mm rotor bolts were perfect at 35mm. with a 1/2in caliper bracket, the fork to bracket bolts were 40mm, bracket to caliper bolts were 30mm.
My only issue is this bracket may need some tweaking. It has the caliper hanging the pads about 1/3 off the rotor, and concentrates all the heat on the top half of the rotor.
As far as this caliper being heavy, it is still way lighter than the factory unit, even with the bracket bolted on it.
My complaint about the factory setup was that even with a stainless line, it would bite hard when you first started braking it would bite hard, but it won't give me anymore past that. This new caliper will actually brake harder when I squeeze harder.
