HPI ignition install
Started by turtle, March 24, 2019, 10:21:06 AM
0 Members and 13 Guests are viewing this topic.
rd400canuck
Hi guys,
Are these HPI's keyed to the crank?
rd400canuck
ok TY...
One more question.... Doesnt my 1976 RD400c have a voltage regulator in it I can use or do I need to buy one for this HPI system as well?
Have to use a aftermarket one, stock one won't work.
I'll have to come back and finish my HPI install post.
Just ordered an HPI from treatland. Can't wait to add this to my bike this winter.
Looks to me as a rectifier only.
Now you'll need to find a standalone regulator.
I wouldn't spend my time on it. I need things to go easy, not harder and eat time experimenting.
Vintage RD building do that enough already!
it will work. however as chuck said, it will need a regulator as well.
as a rule of thumb, rectifiers eat about 30% of voltage from ac to dc. it doesn't really eat it, but clips the wave.., but if you check before and after adding a rectifier, you lose a minimum of 30 % voltage ac to dc measured.
that being said, floating a ground off the hpi and having 2 wire out, will give 2 legs of ac. this can go to a 2 wire rect/reg . or just use the one supplied with the unit. this means ungrounding the grounded leg of the winding and adding a wire and running it out of the motor.
Me? i have time to do this so can experiment, i get why chuck doesn't want to delve into unknowns, completely understandable.
Happy thanksgiving all
I completely spaced that I was ordering from a specialized moped company, where batteries and DC voltage is not a thing and ordered the AC voltage regulator only.
I will try running it with the rectifier into the regulator. If that doesn't work then I will try one of those R/R that I have laying around.
rd350mississauga
I am only getting 5 Volts AC from the yellow "LIGHT OUT" from the stator. Any advise on whats wrong?
1975 Yamaha RD350B USA
1983 Yamaha RZ350K Canada
rd350mississauga
#87
I will check today and revert the voltage at different rpms.
In the meanwhile, I read on treatlands that i need a resistor type sparkplug or a resistor boot. Should i buy this ->
https://www.ebay.com/itm/NGK-Spark-Plug-Resistor-Cover-Cap-Boot-NEW-LB05F-Motorcycle-Elbow-5k-Ohm/202777608821?fits=Model%3ARD350&epid=26017010018&hash=item2f367cc275:g:z4AAAOSw7I5TsZP4:sc:FedExHomeDelivery!14305!US!-1
Also, on another page, i saw that the member bought a rectifier+regulator, will this help me to hook up the hpi unit to the battery to power everything  ->
HPI is out of stock on their R/R, and thats almost a 150 bucks as well. This one on ebay is 10 bucks.
https://www.ebay.com/itm/4-Wire-Full-Wave-Silver-Motorcycle-Regulator-Rectifier-12V-DC-Bike-Quad-Scooter/292689887133?pageci=9699c8a5-f3b7-4164-8330-44b7047f5d53&epid=828261382
bitzz
... or you could use a resistor type plug. Same end result.
rd350mississauga
