VM28 Choke....
Started by AAAltered, February 24, 2021, 04:13:21 PM
Is there *always* a spring inside the choke plunger assembly?  I seem to be missing it on reassembly, and don't recall if it was or wasn't there when I took them apart.  The lever works properly, lifting/holding/lowering the plunger.  The exploded view shows a spring, but there are so many VM variants....
yes, and it needs to be there.
Well I bought an Ebay VM plunger kit.  Plunger itself is the wrong length so I combined my old brass with new bits from the kit.
Given it's nice 'snap' now I suspect the spring has been missing for some time.
50's this week so I hope to get carbs back on and run the R5 for the first time since November...
yup. that should run well.  :clap:
Mine doesn't have a spring on my stock rd carbs. :( Never knew that one lol.
Quote from: m in sc on March 08, 2021, 10:18:15 PM
def should
I cranked the outer spring up to put pressure on the plunger. I bet my choke circuit was leaking. Remember how you said the plugs looked really carboned up when I killed the bike?
Maybe that was one of the issues.
Yep and it makes me wonder what effect I was getting from that missing spring....
can cause rich condition. that spring seals the rubber insert to the port. with no tension can/will leak.
