R5 Vape install
Started by soonerbillz, June 03, 2023, 07:05:47 PM
Is there anything specific on a R5 Vape install vs the RD install?
 What mods to the wiring harness will be needed?
Thanks.
specific on a n r5 vs an rd350? not really except the lack of a bar kill switch on the r5. I have one on my 70, it was pretty easy to do.
chuck has a great thread on installation:
https://www.2strokeworld.net/forum/index.php?topic=855.0
Thanks Mark.
 That's just what I needed!
 :olaf:
RD4140
Hey hey, I actually had a question about the vape install too, so might jump in and hijack the thread for a sec.
So I've installed mine, it sparks and I think it will work just fine. However, and I know M in SC has mentioned kill switch installs before, but where exactly in the system would you wire in a killswitch if you were keeping the relay? I just need a way to instantly cut the spark while commissioning my system. Seems like any talk about a switch involves not using the relay
get a dirt bike kill switch that when you depress it, completes the ground. connect that wire to the blue wire off the coil. (which also goes to the relay)
like this or similar.
https://www.denniskirk.com/emgo/red-crown-kill-switch-46-50480.p218839.prd/218839.sku?cid=17923638713&gclid=CjwKCAjwsvujBhAXEiwA_UXnAOPTHYcI_MhCrt8VoAPR2EWF0sPaucCVQU2Tp0DNCuOkG55wSG1AlBoCHKgQAvD_BwE
TPR5
Yep dirt bike kill switch. I mounted it under the seat . No wires on the bars .
Make sure to take out all the bolts in the Vape and blue locktite everything
Quote from: rodneya on June 09, 2023, 12:18:58 AMMake sure to take out all the bolts in the Vape and blue locktite everything
Thanks for that tip!
