0 Members and 18 Guests are viewing this topic.
Trying to print a tailight for the lc to fit the aeremacchi tail.
I have managed to F my neck up so I cannot lean my head back and my left arm hurts when I hold it out so riding my RD with club bars was out. I could not make it to the end of the block. It has been 5 weeks now so I had to take action. I ordered new bars from EC. I can now ride with only a little pain. I am not a fan of these bars at all. I dont like how it feels. More like riding a dirt bike but hay, I am riding it at lest...
id like to suggest stock rz bars.  i have wide bars like that on  the t500 and the naked concours. def better for bigger bikes IMHO
sorry about your neck, that blows.
Thanks Mark, should have asked. There is something about the club bars that make me feel more part of the bike.
Paul, that probably comes from your nuts being smashed into the tank and seat.  :dawg:
I had a set of these on the ducati. flat out best adjustable clipons, ever. smallest they make is 35mm but a .020 sheet of shim stock will put them spot on on an rd w 34mm forks. use brass shim to go with your gold theme maybe.  :toot: I can not recommend these enough if you decide to go clipon.
https://www.apexmfg.com/all-products/apex-clip-ons/apex-3-riser-clip-on-set
You could saw the ends off some and make them narrower.
Quote from: 1976RD400C on September 30, 2020, 05:34:54 PM
I agree.  I always push the levers and switchgear inboard as far as they will go without fouling on anything, then use the grips to measure and chop em off.
Plumbing tubing cutter ias the way to go.  Nice square cut with no burrs.
Mark,
the idea of the clip on intrigues me. I wonder if a rubber "bushing" can be located instead of metal shims. may reduce the vibrations a little.
I just went for a nice ride with the new bars. I can not 100% sure but the club bars may be about 80 lbs heaver because the front wheel sure seems a LOT lighter now. Power wheelies were fun. Now they are scary.
just fit bar weights, so do not use rubberized shims. i had these on a 1000cc aircooled ducati. lets talk about vibes...    :dance: with bar weights they were fine.
patastinky
pulled it out of the garage, decided I'll start hooking up the tubes :) i'd like to get this running by next year
Ordered reed spacers and extra reed gaskets this morning, FZR1000 clutch plates earlier this week  :dance:
That is some cool technology! My dad told me, when I moved to Western Washington, if you won't ride in the rain you won't ride! Good on ya for getting out there and gettin' it done  :thumbs:
More late-night shopping: Moose manifolds for bigger carbs and replacement fuel valve (two outlets) coming from HVC Cycle. Spending it like I have it!
