Crank bearings preparation ?
Started by Pravin, October 15, 2021, 09:07:30 AM
Pravin
Ok so I have ordered bearings from ebay ....usa n uk
Middle bearings are NOS bit stiff and the 30 40 years old lubricant has turned sticky brown :)
Is it good idea to soak them in 2T oil overnight  before building the crank?
Or just use them as is and they will smoothen up ?
Cheers,
Pravin
put in a few drops of premix oil and spin till worked though.
Pravin
Thanks SC , just doing that now
Regards,
Pravin
Pravin
Just to follow up on one more post..... What's the difference between hollow and solid crank pin ?
My machinist said solid pins are not RD ones ..
These I have bought
I could not find the hollow pin with a hole ..
Regards
Pravin
The crank pins being hollow versus not was just a machining cost savings most likely. If the pin is the same dimension, it won't matter.
bitzz
AFIK all the Yamaha pins supersede to that splined, solid RD400 pin.
Wiseco makes a hollow pin and there is a hollow Kawasaki you can use.
The difference is weight and the splines "hold" better
