135-140 HP CASE REED H2
Built by Henry Wedge. 1st hand experience, it is indeed insane to ride.  :devil:
Re: The Best Possible Transmission Oil
Started by Jessup, March 14, 2019, 07:14:52 AM
~JM~
Quote from: MRDRcycle on July 01, 2019, 06:56:15 PM
Can someone tell me how many liters of transmission fluid a 73' RD350 holds? I can't find my manual :haw:
Look at the engine case near the fill hole. I believe the quantity is listed in cc.
Wet change, just drain plug...1500cc
Dry fill, (new engine rebuild) or a complete drain with the clutch side cover off...1600cc
MRDRcycle
I'm looking at using maxima MTL 80wt. Is that a good wt for normal street use?
old-too-smoker
I say theres lots of options, trans fluid, motor oil, synthetics etc,  and most are equivalent, the main thing to remember is change it often, the cleaner it is, the less problems.
RG400
RG500
RD400F
RZ350
RdsOnly
Worked for Honda shop - Torco 20/50, Yamaha shops Torco 20/50.
I was sponsored by castrol so I use castrol 20/50 no issues.
Gear saver works great but pricey.
If your oil foams it is not suited for wet clutch.
JT
