R5 -> RD “Re-Frame” Build....
Started by AAAltered, September 04, 2019, 10:30:48 AM
Djg8493
when you cleaned your harness, what did you use in your ultrasonic?  I am working on mine now and not sure if I should use WD or order some simple green.
Quote from: Djg8493 on May 04, 2020, 08:38:54 PM
I used Dollar Store Totally Awesome, about 25% with water.  After cleaning I sprayed connectors with WD.  Later I hung it in my utility room to dry for a week or two.   I didn't completely submerge it,
(because it didn't fit) I did each section of connectors at a time.   The heat loosened up the covers on the connectors, allowing me to easily pull them back for close examination and final cleanup with a tiny brass brush.   It came out very good.
Rear wheel and fender on.  Lots of stuff got chromed over the winter....
Very satisfying forward movement today.
Built up the front brake with new shoes and all the rechromed stuff:
Installed rechromed front fender:
Finally rolling again:
Front brakes functional, speedo connected:
Shifter side rearset functional, chain cleaned and installed.  Clutch cable connected.  Left side cover back on.
Steering damper drilled and installed:
Trying a new look with the Moto Carrera pipes, the five year old ceramic coating was showing its age...
Got the rear brakes all set up.  Installed new zirc fittings and greased the swinger and brake arm...
Rear tail light rechromed and installed...
Oil tank plumbed, filled and pump primed, pissing Bel Ray SI7...
Pretty much down to installing pipes and sidestand, then re-timing it since the heads were off.  1-2 more good days and I'm hopeful to be back on the road.
New look with the blacked out Milleniums....
Timing to be set up this afternoon and ((((hopefully))) Fire it up tonight or tomorrow.  It's so nice out I may have a beer and delay till tomorrow...
Up on its own stand for prestart timing.....
And with that, it is officially summer!
davedogg
1969 Yamaha L5T Trailmaster,  1973 RD350,  1973 Honda CB350G,  1976 Yamaha RD400,
1983 Honda NU50,  1983 Vespa P200, 1997 Honda Nighthawk,  2012 Moto Guzzi V7
very nice..  glad you got the 'sandy' out of it. that has to be a releif.  :cheerleader: :patriot:
