TM32 conversion
Started by Kawtriplefreak, January 19, 2021, 10:36:11 AM
My good friend Frank B came over day before yesterday and we started prepping our TM32s for installation. We used 3 MM OD brass tubing sourced from McMaster Carr for the oil lines and a 7/64 (2.7 MM) drill bit. We had to ream the holes just a bit and then a drop of red loctite and Bob's your Uncle.
 :clap:
Way to join the TM32 club!
Where are you starting with jetting?
350GUY
Is the OD the same as the OEM RD350 VM28 carb at the reed (intake/engine side)?
No had to buy new intakes. It is 39 MM.
I put TM34's on my RZ Banshee 421 motor, and had to lean the needle jets down a few steps.
Maybe it is just me, but getting the cable back into the slide is a major PIA. That spring drove me bonkers.
Quote from: rodneya on January 19, 2021, 05:04:32 PM
there's def a method, when you get used to it, it gets easy
One word. Forceps. Game changer for sure, was recommended by a forum member.
Quote from: Czakky on January 19, 2021, 07:31:32 PM
Gonna have to try that next time.
Hemostats work great to compress and hold the spring while you get the cable and plastic jammy situated.
Playtime was limited today. I got one side disassembled and the reed block cleaned up. Did a quick mock up.
It fills the hole up. Air filters will be close...
Quote from: pdxjim on January 19, 2021, 08:31:20 PM
That's what I meant
I got initial jetting specs from M in SC ( Thanks Mark!!) and ordered the brass from Niche Cycle.
Main 230
Pilot 40
Stock needle
P6 needle jets
Clip will be in the middle and air screws initially at 1.5
I also ordered some P4s and received a set of TM28 slide springs. The latter should help with the throttle effort and save my old wrist.
 :clap: new shiny bits look nice tucked in there  :bacon:
