NoRiders
Got the side cover issue sorted....shaped a good chunk off the top corner so the cover will jiggle in snugly and the clutch rod sits in the rubber bush.
Pleased I had the scrap/damaged cover to practice the shape on....learnt a lot and the final effort turned out OK I reckon.
Also, found a compression spring, but need to adjust the clutch actuation and cable adjustment to set the lever position.
Run the 1-3 throttle cable and fixed it with a P clip to the spine, cables run to the carbs nicely and between the carbs to the oil pump.....I'll need a longer one making up as I need another 3" as the bars are wider, I might have a go myself to be honest.
Unless anyone knows of a 1-3 for a twin trials bike that'd work with the GT200??
economan
I fell in to a burning ring of fire,
I went down down down, till the flames got higher
And it burns burns burns, the ring of fire,
The ring of fire.
Johnny & June would be proud. :celebrate:  Cant wait for the "Sunday Morning coming down", reveal.  :whistle:
NoRiders
Quote from: economan on May 28, 2020, 06:57:41 AM
The ring of fire.
Haha...dont call us...well call you....next!!.
Controlled fire would be a good thing....reveal any time distant. :)
sav0r
The side cover is looking factory. Very nice!
NoRiders
Quote from: sav0r on May 28, 2020, 10:04:22 AM
Thanx...it'll look a bit better with a fresh coat of paint. Still a ways to go yet. :)
sav0r
Yeah, I can see it. The finished product is only going to be better.
toffee
Quote from: NoRiders on May 28, 2020, 11:59:11 AM
That was some curve ball thrown at you with the side panel, nicely sorted though, looks good, good fix.
NoRiders
Quote from: toffee on May 28, 2020, 05:12:22 PM
Thnx Toffee....Even in a game of curveballs....I didn't expect or anticipate that one ;)
NoRiders
While fiddling around in the clutch & oil pump area, I realised I didn't have a cable terminal for the oil pump lever.....so, I made one.
As you can see the top of a connector block fitted the bill.....drill one hole and slot.
Mind you, given it's importance I'd lost my bottle and ordered a genuine Suzuki part.
The bodywork, headlight cowl, tank and seat have been picked up by my painter/sprayer mate.....more anon.
One last job before it went to paint, position the ignition switch....it's not connected to the ignition but will switch a component earth...the run/kill switch is the live.
I like it in this position.....and, no I don't think I'll break the key. The switch is ex forktruck and the key is locked when in the live/on position, so it won't fall out while underway.
If I do break it, I'll replace it with a simple push on/off switch.
I've gone though the carbs again, the main jet looks to be 87.5 which isn't the stock size I think?...can anyone confirm?
Indicators arrived.....can you see them?
That's it for now....thanks for checking in - Colin
NoRiders
Any colour you like.... ;D
RustyRD
one vote for Guards Red, the build has been moving along.  :clap: :whoop: :whoop:
economan
NoRiders
Quote from: RustyRD on May 31, 2020, 08:21:19 AM
Ha...no not red. The build sure has been moving forward....just got to keep the momentum going now. :)
NoRiders
Quote from: economan on May 31, 2020, 12:25:11 PM
Tins, Miami blue & black
Blue is in there...;)
Think Suzuki GSXR triple blue/white colours in a retro 70s style.
