Yamaha SRX/RD Hybrid
Started by BlueR32, November 14, 2021, 05:57:13 PM
BlueR32
Hi 2SW! Just re-joined the forum after a couple of years in the wilderness after I sold by GT750 & RD400 projects to fellow forum members. Thought you might be interested in this, my latest project. Picked up a 1987 SRX250 roller a while back. Brought back a RD250 motor from Barber VF this year and decided to do the transplant. So far so good!
THAT, friends and neighbors, is going to be super cool. :thumbs: :vroom: :burnout:
I had the same thought a few years ago, posted it on the old forum. Then someone came along and offered me way too much for the SRX! Looking forward to this thread.
Cool! :clap: What Yamaha should have built back in the day.
Might even deserve a 350 top end too.  :wink:
BlueR32
#6
Started dismantling the RD250 motor. Should have loosened the drive sprocket while still in the frame but got ahead of myself. That thing was on as tight as a camel's arse in a sandstorm so had to channel my inner McGyver. I didn't want to risk damaging the casings so I backed the motor up to the vice and used an old chain I had lying around. Applied some heat to the sprocket & nut and off she came.
BlueR32
Good to know! Thanks for that
BlueR32
#10
The RD250 motor came mounted in a chopped frame. So I was able to graft the bottom section with the front engine mounting points onto the SRX frame. Here is after cleaning up the initial tack welding and adding some bracing around the headstock.
50gary
I'm always amazed the amount of brackets and tabs on a frame.  Looks like a good start,
I like cross-pollinating.  Basic hot rodding at it's best.
  Cheers, 50gary
BlueR32
First experience of vapor blasting and I am well pleased (in the words of Allen Millyard)
Where is your vapor blasting being done?
