Dead RD400 resurrection
We did one on Frank B's 400. It will miss the mag.
JBeasty
Awesome, Thanks for chiming in. One less thing to worry about.
1977 RD400
Quote from: JBeasty on March 29, 2023, 03:33:40 PM
When you don't have a mill...  Not perfect, but not bad! Took me a while to make though. The caliper really takes up a lot of space between the forks. Looks like it will hit the wheel. Hopefully an optical illusion.
Quite impressive. That looks really nice.
RSW46
Nice work on the caliper bracket,
Robert
JBeasty
Thanks everybody. I can't take full credit. This is Marks (m in sc) design.
http://www.2strokeworld.net/forum/index.php?topic=184.0
1977 RD400
JBeasty
#170
More from the Neanderthal machine shop! Center of stock rotor to align new disk to caliper.
EDIT: Question for Mark - This is only about 10mm (or 0.4") thick. In your SPEED SHOP post, you say it should be 13mm (or 1/2"). Will this work, or can I space it out a bit more with washers? I guess I could mount it up and see for myself...
1977 RD400
agreed. if you cant shim the caliper in any further, and have it clear, you will need to make a 2-3mm shim behind the spacer, aluminum will be fine for this, ut im pretty sure you can space the caliper back and get it to work.
JBeasty
Got it. I'm guessing I shouldn't use washers to shim the caliper either?
1977 RD400
you can use washers or spacers to shim the caliper, thats fine. 3/8" id ones will work, you may want to get some thick washers or spacers for final use if that works.
JBeasty
Thanks Mark. Wheel is all apart to get powder coated, so I'll play with it when I get it back.
I got the top end installed, head came out OK - not perfect. But that's probably a good thing. Maybe It'll keep me from obsessing  and trying to get everything on this bike absolutely perfect.
1977 RD400
TPR5
JBeasty
#177
I'm still here!! Putting my rear wheel back together and can't remember how the inner spacers go. Is it the first image or the 2nd?
1977 RD400
pretty sure its 2 but will be super obvious if its wrong
Quote from: JBeasty on June 25, 2023, 09:15:23 PM... can't remember how the inner spacers go. Is it the first image or the 2nd?
yep, 2nd :thumbs:
RD400 C/D/E Rear Wheel bearing/spacer/collar assembly order (repair manual error)
https://www.2strokeworld.net/forum/index.php?topic=693.0
